I do it not full blast, but I do it.
You know how much water is lost to leaks in all of the underground pipes? my tap running for a few minutes ain't nothing in comparison
wow check thisNo but every little helps. While independently you may not make a difference, if we went with similar proportions to the poll, and assumed 1/3rd of UK leaves their tap running when brushing teeth, that would indeed equate to a lot of water
Realistically, though, I imagine the numbers are a lot lower
According to the company’s annual report, Thames Water is the worst offender as it loses around 179 litres of water per property each day. The best is Southern Water which leaks less than 80 litres per property per day.
Overall leakage levels have increased by 1.2 per cent on the previous year and CCW said it was concerned that the industry’s efforts to reduce leakage have flatlined over the past five years, which could undermine campaigns to help and encourage consumers to use their tap water more efficiently.
I shower instead of bath and only use the washing machine twice a week so sure save more water than most people.This logic is a bit dim, isn't it?
Yes, old school. We have an impact on the environment by just living. Do we just stop? Turn all the cars into an artificial reef? Live in a cave and eat only our own toenail clippings? No.
Because there’s no middle ground or any point in trying? Are you mad?
Is leaving the tap running mad? If so then yes. Lighting your home isn't necessary, you can just go to bed when the sun goes down, that's better for the environment
That also goes for the private utility companies that suck at maintaining their networks, can’t eat into their profits for maintenance now can we. But just because they suck, doesn’t mean we, the consumer, should too.
But it's always put on the individuals to save the planet, not the companies making millions whilst wasting energy or water.
seems fine for retailers to leave lights, on, have signs wasting electricity constantly. but god forbid you leave a light on in your own home!
who owns all the pipes the water companies or the government/councils? the government pays you to do maintenance ? water companies don't use their own profits?Maybe if your local council pulled their fingers out, we'd be able to get in there and sort it? Maybe if the regulator of the government you voted in would allow us more money for maintenance, we'd be able to maintain it.
As is, we can only fix about a thousand leaks per week... and even though we know damn well which properties are flooding, the owners refuse to allow us access for repairs, on the assumption that admitting to flooding will devalue their proeprty.
