Stumbled across the user manualk for teh Giugabyte Xtreme X570. Grabbed soime bios screenshots which are interesting
[/IMG]![]()
By stumbled across you mean, you went to their website product page, support section, and downloaded it?
[/IMG]![]()
I'm not confused, 4.1Ghz @ 1.428V suggests they stoked the fire
Sorry you are confused, since my post was about your incorrect assumption, and was written before the image were posted. Ta.
We can’t be sure CPU-Z is picking up the Vcore right there.
but power usage scales exponentially with frequency
Nope - still not confused
In a round about way that would be correct, wasnt there yesterday thoughBy stumbled across you mean, you went to their website product page, support section, and downloaded it?![]()
Yes, they could be reading the same thing from the processor, and misinterpreting it on the basis they think it’s an older generation chip.CPU-Z and HWinfo are in the same ball park for CPU vcore
This chipset chip is the same as the IO die on the processors themselves, and is effectively a massive overkill for 99% of the users out there.
I don't know why AMD didn't design something else for a chipset.
Because of it, the mobos become so expensive.
I don't understand why two 75 sq.mm dies + one a little bit larger should be sold for $750.
It boggles my mind how small and cheap these chiplets are.
I think you'll find you are... might want to read how power scales with frequency.![]()
So you didn't get the prices you wanted so have gone from the most rabid AMD supporter to being incredibly negative post Computex. It's amazing to see, but still disappointing.This chipset chip is the same as the IO die on the processors themselves, and is effectively a massive overkill for 99% of the users out there.
https://hothardware.com/photo-gallery/NewsItem/48380?image=big_3950x_cpuz.jpg&tag=popupWell if you want to be a pedant, I could have typed 'power usage scales exponentially with frequency because in 30 years of overclocking I've yet to find a CPU where you don't need to ramp up the voltage with any significant overclock and this has a drastic effect on power usage. I'm also not aware that AMD has invented any new physics to avoid this effect' but hey, I didn't realise this was a dissertation.
I'm quite aware of the power laws and how power usage scales with frequency so you get a mutiplied effect of both frequency increase and square law power increase from voltage uplift, I was keeping it simple.
Still ~12.5W per core @ 4,1Ghz is a good result for AMD (assuming the 200W in the images is correct). Odd that everyone jumps on 5.5W but doubts the vcore, amps and package / core power readings.
12.5W @ 4.1Ghz would give us 100W + SoC power on a mildly overclocked 3800X which is a little above the stated 105W TDP and so seems to be in the ball park.
In my view these high core chips are about efficiency, the 3950x can run 16 cores at 3.5Ghz, giving you the equivalent of a 7Ghz 3800X on a 105W power budget - a fantastic achievement.
If you then have a game or task that needs a few fast cores, it can scale it's power budget to give you a few fast cores (vs intel I9 class) in a way that threadripper didn't so you get a really versitile chip for diverse workloads.
However all core, high ghz will have a high power cost as there is no free lunch, the images show 1.428V @ 4.1Ghz and 1.572V for 4.25Ghz, so even if there is an offset issue somewhere in the vcore reading, you're pushing an extra 0.15V for 0.15Ghz which is getting well into law of diminishing returns.
Also it's notable there are no higher overclocks, they stopped at 4.25Ghz @ indicated 1.6V.
Odd if it was so easy to go faster they didn't post something a little more exotic.
but... when reviewing, one has to use the best available hardware. That's AMD now?![]()
For me this puts x570 in whatever category is opposite of premium and desirable.
Why would I pay more for a board that consumes triple power and doesn't downclock?
