The choice is yours to make really. I hard wired my Viofo A119Pro. I just used a hard wire kit I picked up from Halfords (Realised afterwards I could have bought the exact same kit from FleaBay for half less than half the price..Doh!)I just put a Viofo A129 Duo in my car and I'm pretty pleased with it for the cost. It's only 1080p 30fps (front and rear) but the footage seems pretty good to me. I'm wondering if I should hardwire it with the 3 wire kit, but I have two usb ports in my glove box that are ignition live, not sure I'd get much use from the parking mode, I park on the road but the car isn't currently used enough to keep the cam running 24/7. Any thoughts on bothering to hardwire it?
I just piggy-backed off the back of the fuse supplying the 12V socket. Reason I did it was to make it a neat/subtle installation. Having wires running here and there is not a good look.
Not sure on the actual law but have mine on the passenger side of the rear view mirror as high as I could.What is the law for attaching your cam to the screen. I read no suction cup over majority of windscreen. Can someobe explain.
I'd go as high res and as best quality that I can afford to be honest. The ability to read reg plates at distance might prove invaluable in the event of an incident.Thinking of getting a front and rear dashcam. Like the look of the Blackvue 4k dashcam. Is that going a bit overboard?
Would be getting it fitted by them.
How many gb sd card will you need for 1080?
I used 32GB for 1080p60 recording which seems to last just under 24hours before having to start deleting the first recording.
Halfords have some decent offers on until tomorrow, half price module with nextbase dashcams +10% off, ended up getting me and the gf a 522gw + rear window camera each for just over £260
