Funnily enough I went for a Survival run on D1 last night. Only two of us sadly and I extracted without any real drama but it was like putting on a pair of well worn in jeans. Just perfect.
Woah what happened? Everybody was praising TD2 when it came out. I was just thinking of buying it.
I've heard a fair few complaints about loot as well but I don't know enough about the retail game to know how much is people complaining because they want everything handed to them on a plate or not.
Yeah the end game grind at the moment is nowhere near rewarding enough, I'm still not gear level 500 and I've got hundreds of hours at WT5. You can literally play for days without getting a single item that improves your build, the loot is hot garbage.
My build isn't close to being min/max'ed either, so its not as though I just require a single god roll item to finish my build. The RNG is far too severe, with multiple RNG levels to it:
1. Need the item to drop at 500
2. Need the right gear brand
3. Need the right talents
4. Need the right attributes
5. Need the right mod slots
Good luck with that.
This is my main annoyance because recalibration sucks ass, far too restrictive. You essentially have to farm for hours(even days) on end just for an item and it needs to be almost perfect as you can only recalibrate one thing on it, otherwise its trash.
Does it really matter that you're not GS 500? You know that as soon as you hit that, they'll increase the max anywayI'm "only" GS 493 and my build rocks but I get your point generally, there is a pretty big wall that everyone seems to hit at endgame in terms of getting anything new that's actually useful.
Surely shoulda learned from TD1,but they made to many changes in gear,crafting etc.Which didnt worked obviously.
Would probably have had people complaining it wasnt different enough then
Whens TU5 due to drop? (Uplay appears to be screwed at the moment)
I don't know if you know but its very easy to get gear score of 500! in fact way to easy I got to level 30 and had gear score of 500 in one hour , All I did at level 30 was go right in to bounties with another guy who had gear score of 500 already and he dropped all the 500 gear score items for me to useThat's the easy way to get the max score.
If anyone wants a boost in game message me and ill help
Literally all I have done at max level is epic bounties runs and have had loads of 500 Green Score gear set items drop.
