Ha. But they're my little cherubs?
They have wetsuits for the paddling pool too; bet that yanks your crank!![]()
Your trolling surely!
I've thought about doing this before too...
As your tap's inside, you might be best off using one of these, then connect the output to your current tap. You then will have a controllable temperature tap, with a hosepipe connection.
Although I'm not 100% sure about that particular one, I believe most are adjustable. Think of the temperature only dial in a shower, you choose how hot/cold you want it to be via that, then turn your tap on/off for the flow. (you might need to look into specific ones of those to get one that's adjustable as much as you need, but it's a startThat looks cool, though I can't see how it would work with my configuration. How would I get only hot or only cold? Can't tell if that's flow adjustable for each of hot and cold or not.
Same as mine. Works well and doesn’t look like above. I take the hose connectors off when not needed.Gonna go for another single tap and a three-way hose connector. Cheapest and easiest solution. Will report back with success / failure.
Thanks all.
S
I wondered if this might happen. I do have a fancy braided hose pipe so hopefully that won't happen, but meh worth it and they're cheap anyway.I have one, only problem is the hose pipe has expanded since getting having hot water running through it!
Yes good shout but each tap has a check valve built into it, not visible from the angles shown.Just a thought, but if you going for the 3 way hose connector option it might be worth adding check/one way valves near each tap so you don't blow cold water back up the hot supply, or vice versa.
