I'm using the £40 X-Tools one and have used it for BB's and wheel bearings without issue - but it doesn't come with small bearing adaptors for wheels its still quite easy to keep it straight. Top tip - wheel in a truing stand with the stand holding the hub works great - you have two hands free and it's kept nice and level. Before then sitting on the floor with the wheel between your legs also works well! YMMV, I've probably only done a dozen bearings but no issues with it.Anyone (jonnym) got any recommendations for a bearing press set. Got a big old bar for my bottom brackets and headsets but want something for wheel hubs that's a bit more accurate. Seen the park tools but it's a bit expensive,wondering if there is a cheaper alternative.
I had a fiddle with the big Park HHP-2 in a LBS and it's superbly made, but complete overkill unless you had a fleet. A real workshop tool!
Well worth keeping a selection of old bearings to use as spacers to help drift wheel bearings in. Although last time I used spacers which came with a Tacx trainer thru axle adaptor, on top of a washer which was the perfect size over the outer race to get a small bearing in an annoying recessed freehub.
Hear lots of people using threaded bar and a load of nuts & washers but when I looked at that (and buying the adaptors) it would work out similar money to the X-Tools press.
Can't remember where from, but doing some research and hunting around I found one of these from park, but listed as 'universal' rather than a specific size (like that one) but costing about £20. It might have even been listed as for headsets, but I've used mine on BB's. I have one of the Park BBT-30.4 but could never get on well with it. Not enough force to fit bearings tidily/straight/easily, while also not really great at removing, again too much force. I found drifting them out worked better. For BB's & hubs I found having a large selection of socket sets (that the tool fits through) so you have some really big & chunky spacers! Probably more of a tip for BB's.
Good stuff, although on 'paper' your practice climb looks harder - ramp at the bottom and steeper pitches later on. The race climb the steepness is all in the first half in 2 ramps where it looks fairly constant gradient. The corners on the ascent might mean positioning is quite important? Make sure you save something for the latter half as bet over the top is fast! The descent to Achray looks pretty technical, fast and long (if you're going that way). #coachThe main climb https://www.strava.com/activities/2495941889/segments/62813146744 I was 30s faster than my best time but riding with power I've only managed 10:45 @ 335w https://www.strava.com/activities/1473515342#36721932216 so must be sitting at 350w give or take. It was a westerly wind so no help there
Hitting this https://www.strava.com/segments/615850 about 15 miles into the race then two other hills further on after it![]()
