hey guys,
quick question.
on MSI afterburner there are two fan profiles? Fan 1 and Fan 2. They spool up independantly but all 3 fans are working..??
Is there an issue or is this the norm for them?
My GPU has the zero fan capability.
I changed the settings to have the fans on low at idle, but soon changed it back to zero at idle but with a more aggressive workload profile, with fans kicking in at 50c rather than 60c, and a plus 10 rpm to C after that.
My reasoning was that fans can wear out on a GPU, and the card is designed to run at zero at idle so my prrofile reduces that potential wear.
So is that OK to turn them off even when idiling at mid-high 40's when the fans are off?
Yep, why not?
Sorry, just seemed a bit high, but I suppose if its designed to kick in at 60c, its for a reason!
Set a steep fan curve like yourself, and idle up to 50c!
Works for me.
I edited my other post to indicate I use plus 10% with my profile, ie when the fans kick in at 50c they will run at 60% and when at 60c, 70% and so on.
I agree with this - 60 is fine but for literally idle, I'd be uncomfortable with it being 55+ for the entire time my PC is on. There are other components to consider like VRMs which may be neglected without some basic airflow.I know they say 60c is safe for all the time but I prefer 35-45c unless under heavy load. Being cooler definitely will not hurt anything, but being hot might.![]()
