- 4 Aug 2007
- Wilds of suffolk
Thanks, now that damn song is in my head...IF YOU'RE GONNA DO IT DO IT RIGHT (RIGHT) DO IT WITH ME
I should be so lucky
I'd be getting a pro in to do that personally.
Eeh that's nice. Bet it's dead satisfying too. I love scraping gunk and grime off stuff then enjoying the pristine results. Wallpaper scraper is a good shout - soften it, then scrape and wipe off onto rags or kitchen roll. Then the final cleanup is another spray and wiping the floor.Quick update, had a little go ealier today using white spirits and some fine sand paper and a bit of elbow grease
Here's the start
A soak and a scrub
Wiped down
Still some tough patched of glue to get rid of, but a bit more work and
Pretty please with the results, did find the glue would turn to a paste and then it was difficult to get off, Tomorrow I'm going to try and use a scrapper instead, I think it may be easier.
Got some sealant arriving tomorrow to apply once its finished.
Thanks for the advice given, was a big help!!
First time I’ve ever heard of asbestos being mixed in prior to use.Not true at all, you have no idea what was mixed in at the time of installation, loads of adhesives contain asbestos that was mixed in prior to use/installation, thin set mortars, putty, texture coating the list is endless
And don’t have any naked flames in the house when you do it.do it with an open window though!
Or clothed flames.And don’t have any naked flames in the house when you do it.
That would be lovely bought back to life.
Can you see is there are any joins in it? Isn't laid in slabs. If not it's likely an exposed aggregate that has been ground back originally which means you could grind it back some more.
If not some kind of thinners to liven the glue up so you can scrape it off.
You would be surprised, it was thrown into mixes all time, ive found mastic with clumps of chrysotile in it from being added when on site, industry guidelines say materials should always be presumed to contain asbestos, hence why we do surveys before any work is carried out.First time I’ve ever heard of asbestos being mixed in prior to use.
