Spanish article here:
https://www.xanxogaming.com/reviews...s_WHEA_PCI_Express_en_tarjetas_NVIDIA_GeForce
Comments from le Reddit:
"Driver level errors associated with either the PCI Express bus and/or Nvidia GPUs may have prevented the chips from boosting properly - which was interesting because several reviewers today commented on not hitting advertised boosts. The author observed this behavior on both Gigabyte and MSI boards but only with Nvidia cards and at least for their own work decided it was sufficient enough to warrant not publishing any FPS benchmarks until sorted out."
"This is huge dude, he said he got boost to 4.65 GHz with the older 1.0.0.2 bios, even though PBO did not work on that BIOS. The newer 1.0.0.2 (NPRP press code) & 1.0.0.3AB BIOS were limiting his boost to 4.35 GHz
The driver WHEA errors seem to be unrelated and are a nVidia specific problem. They are probably still causing slowdown in benchmarks."
Thread:
https://www.reddit.com/r/Amd/comments/cacasv/very_interesting_writeup_of_an_issue_that_may/
Here's the website translated to English..
https://www.xanxogaming.com/reviews...EA_PCI_Express_errors_on_NVIDIA_GeForce_cards
This is what they wrote about the issue..
During the first three hours of testing of the AMD Ryzen 9 3900X processor, using the X570 AORUS XTREME board, I noticed the problem when PCMark 8 did not pass the first test after 40 minutes (this is a total of ten tests). I noticed WHEA error (Windows Hardware Error Architecture) in HWInfo64 (se this software for PC telemetry, highly suggested).
From there I also decided to pay more attention to HWInfo64 and also checked that the BOOST frequencies of the processor had problems, since it didn’t get to “boost” all its cores to the maximum that it should, which is 4.6 GHz. It reached 4.5 GHz to 4.575 GHz in a pair of cores and the rest of cores to 4.3-4.4 GHz… We used manufacturers chipset driver, we have used press chipsets, as more current chipset driver version, same results.
I thought boosting on 1 or 2 cores was normal. Is it really supposed to boost all cores?
and people are believing u need 12 14 heck even 16 power phases to get a stable overclock. Maybe if we could push the frequency way up but with the 4.6 realms I think any X470 mobo will do
