Hmm, I have to say that's quite different from my experience in Shadow of the Tomb Raider at least (don't have Odyssey) using a 2600. Not looking it as any sort of overall CPU benchmark running at 1440p/max settings, but my minimum was still 70fps and I was GPU bottlenecked 100% of the time using an overclocked 1080 Ti.The 1600 should be bottlenecking the 2080 massively in certain games. For example the third benchmark scene in Shadow of the Tomb Raider probably dips to 50fps even though the 2080 should be capable of pushing way more (very noticeable when you are playing the game in the same area). Assassin's Creed Odyssey also should be bottlenecked.
I previously had a 2600X with a 1080ti so I did quickly learn the bottleneck scenarios which prevented the card being able to hit 60fps.
Assuming I'm interpreting the benchmark correctly, the lowest the CPU would have ever dragged it was 99fps, even if I went down to 1080p or put it on low settings.
. But all capped just before the noise kicks in, so a relatively quiet system.
