RTX 2060 Super, RX 5700XT or RTX 2070 ?
20 Nov 2009
Haarby, DENMARK
I need a new graphics card for my ITX machine after I sold my GTX 1660Ti. So I'm pretty much in need of a card now ;)
However I cannot decide what GPU chipset to go after.
RTX 2060 Super
RX 5700XT reference
RTX 2070 non-super
All 3 are almost the same price in my country.
What card would you choose and why ? I really like the brute performance of the RX 5700XT but I don't know if I'll give up on ray tracing.
The RX 5700XT is faster than the 2060S but same price so if it between them two then go for XT. The 2070S is a bit faster than the 5700XT but usually around $100 higher. It all depends on whether you want to lose the fps associated with RT. 60fps fluid gameplay or 45 fps with RT? I'd prefer the fps.
The AIB 5700XT's will swing performance in AMD's favour imo.
It all boils down to ray tracing. Personally I know I'm gonna put hundreds of hours into CP2077 so for how much of a groundbreaking step RT GI is I would choose the 2070. The extra oomph of a 5700xt is pitiful compared to such a feature. Plus I'm willing to bet the next AC will have RT too so that's yet another reason for me.
In the end I went with a non-rt card last year and starting to regret it. It was the right decision at the time but nonetheless things change and I feel differently about it now.
RTX 2060 Super
RX 5700XT reference
RTX 2070
On ITX machine if you do not watercool, by default you need blower cooler yes? If so 5700XT then.
Undervolt the card to reduce thermals by ~20% while improving perf.
Are you planning to play at 1080p 30fps? Current gen cant handle RT.
I would say 2070S now.
When the 5700XT aib cards are released, then 5700XT.
The 2070 Super isn't a option since it was too expensive.
Playing at 1080p on a TV. Most cards I've seen run pretty well with ray tracing at medium settings though.
I would be fine with 45fps with RT enabled. But I am still very unsure if I need the RT features for my ITX machine or if performance is the main objective. The radeon cards are really tempting.
The ITX machine has evolved from GT 1030, to GTX 1050Ti and then GTX 1660Ti.
Someone buying a RTX2070 Super NOW for Cyberpunk 2077 is like someone buying a 8800GTS 320MB or 640MB for Crysis, and then the 8800GT and 8800GTS 512MB were released when the game was out. The demos were running on a GTX1080TI at 1080p.
Best to wait closer to release if you have a good enough graphics card now.
Wait until Cyberpunk 2077 is released. Getting a graphics card now for the game when it is out in 10 months time is not worth it IMHO. In 10 months time Nvidia might have launched a new range of graphics cards and AMD might have launched more powerful cards too.
There's no new GPUs coming before CP2077 for his budget, plus he said he needs it now. As for CP2077 performance, it's coming out on X1 & PS4. If you understand what that means you understand a 2070S will have no issue handling it even at 4K, and since they're using TA up the wazoo you can downgrade to 1800p with minimal issues.
The Witcher 3 came out in May 2015,and 10 months before was only Kepler cards,which couldn't handle the tessellation in the game,and CDPR released a slider to help. The GTX980 came out a few months later in late 2014 and obliterated even the GTX780TI:
https://static.techspot.com/articles-info/1006/bench/1080_Ultra.png
https://static.techspot.com/articles-info/1006/bench/1080_High.png
Mere weeks later after the game launched the GTX980TI was launched:
https://static.techspot.com/articles-info/1011/bench/Witcher.png
Witcher 3 released on consoles too, and it didn't run that great. The 8800GTS 320MB and 640MB released a year before Crysis came out and when it was released,we saw the 8800GT and 8800GTS 512MB which were cheaper and faster in the game.
So Nvidia releasing better cards when Cyberpunk 2077 is released makes a lot of sense,as it would be the ideal push for graphics card sales just like The Witcher 3 and Crysis were.
The demos were using a GTX1080TI at 1080p,and you can't make a promise even a RTX2070 Super can run the game at 4K fine,when the top cards of the Witcher 3 era,at ultra and very high settings struggled at 1080p and 1440p. The game was also downgraded graphically.
April 2020 is 10 months away,which will make current Turing 20 months old. Guess how long it was between the launch of the GTX980 and the GTX1080?? 21 months.
I would not upgrade a graphics card for the game until we know for certain how well it will run on current hardware.
Edit!!
If the OP is upgrading now just get the fastest card possible.
TBH,I would have just kept the GTX1660TI until the game is released.
Yes. And it came out for PS4 & X1, which is also what CP2077 is coming on. That means it's been developed with that baseline in mind. Meanwhile, GPUs today are many times faster. That's why a 2070 Super will not have issues handling the game at 4K (with the caveat: if there's some extreme setting like supersampling, I'm not talking about that; I'm talking High-ish).
Yes, that would be ideal if these things weren't planned years in advance and they wouldn't need to co-ordinate with a gigantic manufacturing & supply chain.
I can't make a promise, but I can make a bet.
GeForce GTX 1080 May 27, 2016
GeForce RTX 2080 Ti September 27, 2018
Is that still 21 months?
Which is good advice if you want to wait, but maybe you'd rather use the GPU until then. And if you have a strong suspicion a competing GPU won't launch before Fall, then it makes sense. After all, that's almost a year of usage you'd get out of it before the game is out, and then a few more months on top of that before next-gen, and a few more months on top of that if you don't plan to buy the >$1K flagship (since the releases tend to stagger rather than come all at once). If you have an older/weaker GPU waiting is all the more painful. Just think if the same cards today are the exact same cards available on CP2077 launch - that means you've missed out on almost a year of playtime with a great GPU and mostly saved £20-30. Is that really worthwhile? To me no, that's why I'm pondering the upgrade myself.
