upgrade the GPU. lol.If you were upgrading an x99 system what would you get?
I'm pretty hesitant about any future upgrades as when I went from an i7-920/X58 to an i7-5820k/X99 it honestly wasn't that big a difference in day to day use.
Yeah being honest I don't remember being all that excited when I moved from a 2500k @ 4.5ghz to my 5820k. It was faster but I guess cpus don't have that same impact as gpus.
I don't think I'd upgrade my current system CPU/mobo unless I had an app/game where the performance was sub par.
Yep it really depends on what you're doing. I generally don't upgrade until I can see at least a ~25% improvement in what I do and prefer if that number is heading up to 40%. Unless you can see that kind of improvement over your X99 then I wouldn't be so quick to splash the cash.Good post thanks.
Ive just looked at GPU prices too and they are pretty bonkers right now.
I have a feeling my excitement towards upgrading might end with disappointment.
I'll likely have to spend 600 quid to feel a difference at 1440p
Yep, I didn't even give X570 a look in due to the chipset fan! I really like motherboards with a post code display read out but had to forgo that although I did get Flashback.I'm in a similar situation, though I'm really struggling to find a decent motherboard. Most (all) seem like a downgrade, lacking sata ports or post codes, bios flashback, chipset fans which I remember from the barton 2500xp-m days :X
Thisupgrade the GPU. lol.
I've not gone into how loud they are, just remember on my NF7-S v2.0 the northbridge fan failed, ended up just putting some massive blue heatsink on it and it was fine, x570 might work out the same.Yep, I didn't even give X570 a look in due to the chipset fan! I really like motherboards with a post code display read out but had to forgo that although I did get Flashback.![]()
Ram prices seem set to rise (see Japan vs S Korea kafuffle), and I now have a kit capable of 3600mhz for ryzen 3900x if I go that route.I've not gone into how loud they are, just remember on my NF7-S v2.0 the northbridge fan failed, ended up just putting some massive blue heatsink on it and it was fine, x570 might work out the same.
Post codes seem less of an issue on AMD side, basic lights work, CPU, Ram, mobo, hdd. Fair enough, but some boards lack these led lights too O_O
I've ordered a 16GB kit of 8pack 4133mhz DDR4, gonna see how low I can get the timings to go on my 5820K at 2400/2666mhz lolRam prices seem set to rise (see Japan vs S Korea kafuffle), and I now have a kit capable of 3600mhz for ryzen 3900x if I go that route.
