- 27 Apr 2014
EDIT Aug 12 2019:Let me start by saying I was wrong and I apologize for any misinformation I supplied due to my ignorance. I was aware of Third-Party Monitoring Tools not being as accurate as Ryzen Master and I just ignored that fact all together.
I have started testing with Ryzen Master only now to see what the actual clocks on my Ryzen 3600X really is.Although I still get over Max Boost as what is written on the box so I have no recourse to complain to AMD or refund my CPU'S.Also they are still fast little CPU's Still happy.
I have only witness Cinebench20 hitting Max Boost on 2 cores as of testing today.I will test some more with different BIOS and if any change is observed I will post back.
Updates to Precision Boost Overdrive Override for the AMD Ryzen 3000 Series can give an addition 200Mhz added to what is printed on the box.
So I was wondering how much over max boost can you get on a Ryzen 3xxx CPU and did AMD LIE lol.
Motherboard MSI X470 Gaming Plus + 3600X
Max Override Boost 182.1Mhz on 1-6 of 12 cores for total up to 4582.1Mhz.
Settings Used
Anyone have any luck going over max boost clock.
CPU -Printed On The Box
Ryzen 9 3950X -4700 Max Boost
Ryzen 9 3900X -4600 Max Boost
Ryzen 7 3800X -4500 Max Boost
Ryzen 7 3700X -4400 Max Boost
Ryzen 5 3600X -4400 Max Boost
Ryzen 5 3600 -4200 Max Boost
My CPU BOX
Settings Used
My Settings for boost up to 4580Mhz
OS-1903 Build 18362.267
AMD ComboPI1.0.0.3
AMD_Chipset_Drivers_v1.07.29.0115-Release -July 30 2019 with AMD Ryzen™ Power Saver Plan
BIOS set to Enhanced Mode 4 for MSI Motherboard
My settings for videos boost up to 4525Mhz gaming/Cinebench
AMD ComboPI1.0.0.3
AMD_Chipset_Drivers_v1.07.07.0725-Release Day -July 7 2019 with AMD Ryzen™ Power Saver Plan
BIOS set to Enhanced Mode 4 for MSI Motherboard/LCC CPU/SOC 2
AMD ComboPI1.0.0.3
AMD ComboPI1.0.0.3
My CPU BOX
