As the title says I've just got this board and the BIOS keeps resetting.
When I go into the BIOS I am given this message:
"Clear CMOS Information
BIOS has been reset. Please re-config your BIOS setup items if needed"
This is happening when I restart the PC or shut it down and power it back up then go into the BIOS, without removing the power cable.
I've updated to the F4F BIOS, which I installed using Q Flash from the BIOS via a USB Stick.
Unplugged from mains then held power button down for 30 seconds then
Reset CMOS jumper by touching a screwdriver across the jumper contacts
Removed CMOS battery for ~5 minutes
Replaced CMOS battery with known working battery from previous motherboard
However I am still get the BIOS has been reset message, which is preventing me from enabling XMP.
Any ideas?
Any ideas?
