*** The Official OCUK Cinebench R20 benchmark Thread ***
I tried to beat it but came up short :o
Single Core @ 4.45GHz, 512
All Core @ [CCX1 4.275GHz] [CCX2 4.250GHz], 5097
Very nice Multi score there!
I was going to leave it but now I want 5100 for the MP. I'm gonna be up all night (think I may need a cooler other than the stock to be honest).
Stock cooler should get you through the test, I managed those scores @ 1.375V. Wasn't on the limit with a Noctua U12S.
I had to go with a per-CCX overclock using Ryzen Master to really push every bit out. I actually posted a 5100 on the dot but my PC crashed in a subsequent run so there's no evidence :D
My single core score isn't practical, I pushed in a lot of voltage and only OCed 1 core, but nice to see it going over the 4.4 barrier!
Wanting to avoid Manual All Core overclocking and trying to keep a balance of both SC/MC this is the best I have achieved so far without going deeper into memory Timings and Sub Timings. Despite feeding volts the current Ryzen RAM Calculators are not entirely appropriate for Zen 2 and x570 as far as I can see. I have some pretty loose timings and the HWInfo DRAM Voltage of 1.464 is actually ~1.42 on the multi-meter.
I've got 3600CL16 Samsung B-Dies but I cant run at anything 3600 or above as it totally destroys my Single Core boosts limiting them to 4125 or less. *shrug*
These settings see acceptable load CPU Voltages and the systems properly idles with the Ryzen Balanced power plan.
The CPU Vcore offset of -0.10v is the sweet spot for me. -0.50, -0.75, -1.25 and -1.50 all lose performance for me. Full score/monitoring tools in Spoiler tags.
CB R20
  • Multi CPU Score of 7416
    • All Core Freq. of 4125Mhz peak
    • 1.43v CPU Vcore in Ryzen Master
    • 1.34v CPU Vcore in CPU-Z
    • 1.35 CPU Vcore in HWINFO
  • Single CPU Score of 506
    • Single Core Freq. of 4353Mhz peak
    • 1.35v CPU Vcore in Ryzen Master
    • 1.33v CPU Vcore in CPU-Z
    • 1.33 CPU Vcore in HWINFO
3700x @ 4500GHz (4.8v)
Not sure I could get any higher without an electrical issue. Don't want to damage the chip!
Damn it, i'll add it now :p
Haha sorry. I'm in a bit of a OC mood. First time 4500 has stuck for a test and the little extra was all I needed :)
The bad news for you is I've ordered a noctua fan to replace my stock. I'll keep you busy this weekend :D
I look forward to it :D
Adding the picture, was setting Imgur up since I never used it :p
S01zG30
OFFS i just updated the thread, it will have to wait. :)
5345 4.45Ghz all core 1.4V
520 Single core
Going to try 4.5Ghz all core next.
Edit: it boots at 4.5Ghz all core, tried until 1.44V but was not fully stable. I didnt go on after that.
Threadripper 2950x PBO
I'm totally thermally throttled with my current air cooler.
Edit updated when room isn't roasting. Little Noctua U14S air cooler doing it's best lol
