Caporegime
- 21 Jun 2006
Nobody who owns a g sync monitor will buy it.
This is a major issue for me. My last two monitors both being g sync, I now need to buy nvidia.
Or can I use AMD perfectly fine so long as it maxes out the refresh rate of 165hz at 1440p?
I like to buy best bang for buck but it seems that once you pick a monitor you have effectively chosen a side. You can no longer switch unless you also sell the monitor which is a huge pita.
