- 27 Apr 2014
Ryzen 3600X Tested Tight Ram Timings 2133Mhz 2400Mhz 2933Mhz 3200Mhz 3733Mhz 4000Mhz 4200Mhz 2560x1440 Ultra settings.
There are plenty of 1080P and lower test,these test are aimed at people who blew there cash on $500+ graphics cards and are not quite sure if they should upgrade their ram.I say no if you game at higher resolutions.
Battlefield V I noticed that above DDR4 4000Mhz average FPS started to climb.Which is weird because memory clock/fabric clock/memory controller switch from 1:1:1 to 1:1:2 so memory controller gets cut in half.
A Plague Tale Innocence had two areas where FPS lows dropped to 16 FPS and 7 FPS in the same spot on every test
All games gave the exact same game play every test.
Video of game areas tested
RAM TIMINGS USED FULL NO AUTO
♦ 2133Mhz (16GB)CL10-10-10-10-21
♦ 2400mhz (16GB)CL10-11-11-11-21
♦ 2933mhz (16GB)CL12-14-13-13-26
♦ 3200mhz (16GB)CL14-14-14-14-28
♦ 3733mhz (16GB)CL16-17-16-16-34
♦ 4000mhz (16GB)CL16-18-17-17-36 -(memory clock 2000x2/fabric clock 1800x2/memory controller 1000x2)
♦ 4200mhz (16GB)CL16-18-17-17-36 -(memory clock 2100x2/fabric clock 1800x2/memory controller 1050x2)
COMPUTER USED
♦ CPU - AMD 3600X With MasterLiquid Lite ML240L RGB AIO (Fans 55%)
♦ GPU - Nvidia RTX 2080
♦ RAM - G.Skill Trident Z 16gb DDR4 (F4-4000C18D-16GTZ) (2x8GB)
♦ Mobo - MSI X470 - Gaming Plus
♦ SSD - M.2 2280 WD Blue 3D NAND 500GB
♦ DSP - LG 27" 4K UHD FreeSync Gaming Monitor (27UD59P-B.AUS)
♦ PSU - Antec High Current Pro 1200W
VIDEO INFORMATION
► FPS Monitoring : MSI Afterburner/RTSS
► Gameplay Recorder : Nvidia Shadowplay
► Edit Videos : VSDC Free Video Editor http://www.videosoftdev.com/
COMPUTER USED
VIDEO INFORMATION
