NZXT H200.What case are you using please?
Steedie. I can see you have the Alex drawers at one end. Are there drawers the other end, or is there just a leg holding the table up? How solid is the worktop? And how does it feel compared to a solid wood top?![]()
Nearly finished! Couple more frames to go up (Infinity War and Captain America) then I think I’ll be done
I want the 186. So you think Alex drawers one end and two ikea legs the other would be solid enough?I have a filing cabinet underneath but also two legs. The Karlby is a properly sturdy worktop, so the 186cm is more than happy to be supported at just either end. The longer one I think you’d want to support in the middle as well just to prevent any sag
Which legs are they?I did the same, very sturdy.
Case has gone under the desk. Extra crispy clean now.
Ive got a Steelseries mat that’s curled at one corner and won’t go flat. I don’t think anything has ever bugged me as much.Recently switched back to my preferred OS, MacOS. Mac Mini + the new LG Ultrafine. The desk mat is so new it's still not flat at the edges! Also need hide the external SSD under the desk with a longer USB-C cable.
Stick it to the underside of the desk with velcro. No need for a longer cable and even tidier.Recently switched back to my preferred OS, MacOS. Mac Mini + the new LG Ultrafine. The desk mat is so new it's still not flat at the edges! Also need hide the external SSD under the desk with a longer USB-C cable.
