- 28 Dec 2017
- Beds
Don't mix cables from different sources - it can end in bangs, smoke, and dead components.Thank you, guys. I've purchased my GPU. The only problem I have now are the PCI-e cables. Are any PCI-e cables good enough, or do I need my PSU's?
Different manufacturers use different pin arrangements on the PSU side. So it's risky. If you're willing to measure the pins and confirm the cables have the same layout, it will be ok. But best to be safe.
