I'm been in this industry long enough to know that every motherboard manufacture screws up at some time so I never let that put me off buying their product again..... Completely put me off ever buying MSI again.
Yeah but later on the 4th series might be support if the BIOS chip is bigger, all they've gotta do is drop 1st gen support for the extra space.I would not be too concerned about waiting for or getting the MAX. If both boards are available and at the same price then may as well get the MAX but realise that the only difference is the large bios chips which basically only allows all older CPU's (which most people don't have) to be supported as the same time as new chips.
If you're getting a new Ryzen CPU then just get which ever board is available and cheapest as they will behave exactly the same way.
If you're seriously hoping the Max boards are going to work nicely with Zen3 when they don't even work properly with Zen2 yet then you're barking up the wrong tree.Yeah but later on the 4th series might be support if the BIOS chip is bigger, all they've gotta do is drop 1st gen support for the extra space.
I
Exactly. I can't see MSI releasing the MAX boards without doing a whole lot of testing with lots and lots of Ryzen 3xxxx CPU's. The larger bios is a convenient distraction to give them time to get the issue properly sorted.The max boards are not even out yet, how are they not working
I was looking at X570 for the same reason. Problem is, I'd want to go for one with WiFi, and the cheapest option has terrible WiFi. So I'm left having to wait for a B450 MAX and a WiFi card, or wait even longer for a B450 MAX with WiFi. It is proper annoying as the rest of my build is waiting for it.Yeah, I don't know what do do now. I'm not buying a B450 board until the whole BIOS/MAX situation is resolved, which either leaves me with buying an X570, which I think are far too expensive (IMO, relatively speaking) or just going for Intel. It's put a massive dampener on the launch for me.
I'm not hoping at all, just saying it's possible, the reason why the board is struggling is because the BIOS chip isn't big enough, with MAX they'll double the size which means Zen 2 will fit on easily and with 1st gen support dropped 4th gen Ryzen could work, theoretically. We all know if you're wanting next gen support then the X570 is easily the go to, with PCI-E 4.0 and better BIOS.I
I don't think that's quite accurate. The smaller chip size is why the updated Bioses for the B450s use GSE Lite - it's a separate issue.the reason why the board is struggling is because the BIOS chip isn't big enough.
Why do you think they haven't announced a release date? What I'm saying is they're bringing out these boards ostensibly to allow both Zen 2 support and the graphical Bios interface. They haven't set a release date because the Zen 2 support isn't there yet.The max boards are not even out yet, how are they not working
You might want to delete that link before you get an involunatary holiday.Bargain
Bargain
