DOMINATOR PLATINUM Advice
8 Jan 2010
Is there any difference between the older,
DOMINATOR PLATINUM 32GB (2X16GB) DDR4 PC4-25600C16 3200MHZ DUAL CHANNEL KIT
https://www.overclockers.co.uk/cors...dual-channel-kit-black-cmd32gx-my-48s-cs.html
And the New,
Corsair Dominator Platinum RGB 32GB (2X16GB) 3200 MHz DDR4 Dual Channel Memory Kit
https://www.overclockers.co.uk/cors...z-dual-channel-kit-cmt32gx4m2c-my-4br-cs.html
Apart from the obvious RGB lol
Thanks
to make it easier if you could list the model numbers? theirs so many different ones, im looking at getting a pair of these myself aswell for my ryzen build
oh sorry you have linked them now as i was typing lol
And the New,
Thanks
i cant really see any difference timings are the same unless anyone else knows of any differences
Thx, I don't care about RGB if there the same I will get original as cheaper
The original also has a better build quality, the new RGB tops are plastic not metal etc...
Though personally I can highly recommend the Team Group Dark Pro 8Pack memory, much better quality in build and memory ICs, plus better performance :)
Sorry for hijacking the thread.
I own a set of the original Dominator 16GB if I was to buy the same set would that be ok to pair with my older set? I know about timings etc Cas16 XMP 2.0 that is all matching even the part number is matching.
im not sure it looks like it should be ok if there the same speed and timings maybe contact corsair to confirm
From what i've read as long as there the same as the pair you already have (timings etc) because they are only dual channel and you keep the pairs together they will be ok
Thanks guys
I will just purchase them and see :D
