Have you configured the RAID controller?
Is is possible to boot from the SSD if I have th Raid controller disabled by any chance?
Don’t suppose anyone has a spare hard drive Allen key for the HP 54L do they ?
Went to clean mine today and no key was in the door![]()
It's only a torx key. Nothing special. Should be able to pick a set up cheaply locally.
im struggling to into the Dynamic Smart Array screen to configure my raid. I've pressed f5 during bootup but keep booting into windows. What am i doing wrong?
Thanks, looks like a useful bit of kit. Just wish I’d discovered these before my Gen8 was full of dust.If you search the computer section of the auction site for 'gen8 cotton' you will be rewarded with an item containing a neat aluminium frame and three filter sheets. I'm pretty sure the filters are no more made of cotton than I am but do look like they're washable. The frame fits inside the Gen8's door, holding the filter in place. I don't know how effective it is yet but it looks like it should catch the worst of the dust drawn in without restricting the air flow too much.
Although it's supposed to be shipped from China, mine actually shipped from the UK and arrived in less than a week.
This has been a PSA.....
Sounds like your embedded flash memory with the SSA software has gone bad, mine did when I did a firmware update - its a known fault and you get a motherboard replacement if your Gen 8 was still under warranty and it happened. You can work around it by downloading the following ISO, burn it with Rufus and boot from it. You can then configure your array as required.
https://support.hpe.com/hpsc/swd/public/detail?swItemId=MTX_fac66a01809546579a9c3fd050
have a gen8 microserver, can i use the 2nd network port to supply internet to a tv directly? if so how?
thanks
thanks, yes agree with that but would the option, w10 but not sure where to startYou could, but the practicalities depend on your choice of OS, a switch is cheap, transparent and doesn’t require the microserver to be powered on.
Received my “cotton” filter kit. Mine did come from China and so delivery was around three weeks. It fits nicely tough and was only around £9 delivered.Thanks, looks like a useful bit of kit. Just wish I’d discovered these before my Gen8 was full of dust.
I have almost the same spec and don’t experience any of these issues. I am currently running 6.7 U2 but have run pretty much all the versions before that. The image you have should work fine. Where is ESXi installed? I installed ESXi to a USB stick plugged into the internal port. It is also possible to install to an internal Micro SD card, but I have heard of some issues with that. It might be worth checking the RAID configuration in case it is trying to check for a missing drive.Hopefully this is the right place to ask. I've just acquired a Gen8 MS and I want to get exsi going on it so I can learn the environment. A colleague has helpfully installed exsi already but it seems to hang a lot while navigating the admin panel, especially when trying to view storage properties. When attempting to restart or shut down the server it never seems to be successful and I have to power it off (I haven't tried leaving it for longer than 30 minute tbf).
The image that's currently on there is HPE-ESXi-6.5.0-Update1-iso-650.U1.0.6.5.1. MS spec is Xeon E3-1220L V2, 16GB RAM, and 1x WD Red 2TB.
