- 6 Sep 2016
I was more just asking for clarity on what you were saying, the previous post was potentially a bit ambiguous as it wasn't clear if you mean to say that amps are improving except for class D amps or that class D amps are the exception and are improving.
Obviously manufacturers do try to continually improve, certainly with regards to efficiency but there isn't really much to be done in terms of improvements to sound that could actually be perceived.
My point is more like some guy has say some separate amps from ABC Amplification etc.. Ltd in order to bi-amp his top of the range speakers from XYZ speaker company used at the front of his setup, he's got some big multi channel power amp for the rears etc.. (whatever.. he's spent some money finding some set up that he likes). He also has an AV pre-amp from ABC Amplification etc...
10 years later Dolby and others have new standards.. his pre-amp is out of date and doesn't support "Dolby Super UHD sound"... he's a bit gutted, his mate Brian has the new standard and the under the floorboard upwards facing speakers are great.... Well he probably only really needs to swap out the pre-amp and add in a couple of speakers. Any new power amp models form ABC Amplification etc.. Ltd, if level matched with the existing ones he has, won't likely make any perceptible difference. The XYZ speaker company's new range might be better, they might also be worse... or them might just be more or less the same thing but in a slightly different box.
Yeah for me to upgrade my non hdmi, non DTS master av pre I just remove my av pre and buy a new one, keeping the channels of amplification.
As power amplfiier sound I did notice difference between two brands . Not as much as pre Alps bit it was there, if you had bad matched combo then change one of the bad match amps it made a difference. Ie harsh amp harsh speakers, change to soft power amp and that fixed it.
