You can adjust your tune with Ecutek app provided you have their OBD and licence with the tune.Not sure how I feel about flashing a car with a phone, didn't even know it was possible!
Some of these maps seem a bit sketchy without AFR gauge. I take it the good tuners cut them back a bit to account for fuel pump age etc?Current gen Ford stuff via mountune doesn't even need a wired connection any more. All done over bluetooth
Makes sense, I'm amazed that you can modify/flash stock ECU's. I thought they would have tried to stop that on the higher models of cars; shows that modern manufacturers expect it. I remember a friend of mines dad buying a Evo 8 MR FQ400 back in the day, the amount of anti-tamper stuff on that was insane. Even to put a lead into the ECU it had anti-tamper screws galore.OEM ECUs are worlds apart from what most people think when theyre used to tuning or seeing a standalone being tuned.
Factory wideband which is going to be far better calibrated than any aftermarket wideband outside of something like a Ballenger AFR500 paired with a lab grade NTK sensor.
Windowed knock control with OEM calibrated frequencies and thresholds, and in some cases Ion sensing knock control via the coils too
Every single control system has dedicated monitoring systems, any one of which can apply a cylinder fill, rev limit or other failsafe if something isn't right.
Yes you can, and the fact there is now some bolstering means shoulder rubbing (or falling into each others laps) when cornering is now no longer an issue as well.Excellent upgrade, Acme. Can you actually fit two normal-sized adults in there side-by-side though, or is shoulder-rubbing and trout-shoulders a requirement?
I'm dealing with a 1990's ecu which is well back in the day hence why I run a piggyback e-manage ultimate which is maxed out also from back in the day. Basically windows 98 era stuff. Thought about going Link G4 or Wolf V4X for the next upgrade to get a much more precise tune on the injectors etc. Need a trigger crank wheel however and coil pack conversion but it will make a world of difference. You can tell the Distributor is an old fashioned way of doing things but it works, get a slight glitch/hiccup every now an again however as you can tell everything is maxed out on the ECU.
Edit: e-manage etc while did the job were garbage 20 years ago, let alone now.
Interested to hear why you think this, btw the emanage ultimate is from 05 / 06 not 98.
https://frsport.com/greddy-15500501-e-manage-emanage-ultimate-fuel-ignition-controller?redirect=1¤cy=GBP
