- 27 Apr 2014
I am testing last couple days on 3600X using AMD overclocking and I get the same results in gaming 4250Mhz thru to 4500Mhz,I think I will stay at 4250Mhz for a bit.
Full load CPU drops to 1.25v ,set to 1.3v in BIOS
DDR4 CL16 3733Mhz @ 1.35v
Highest temperature recorded while encoding H265 12bit video 72.9c and CPU Fan RPM hit 1721 ,not bad at all I would say.
https://postimg.cc/G9gjjYR9 full size
COMPUTER USED
♦ CPU - AMD 3600X With MasterLiquid Lite ML240L RGB AIO
♦ GPU - Nvidia RTX 2080
♦ RAM - G.Skill Trident Z 16gb DDR4 (F4-4000C18D-16GTZ) (2x8GB)
♦ Mobo - MSI X470 - Gaming Plus-BIOS AMD ComboPI1.0.0.3AB
♦ SSD - M.2 2280 WD Blue 3D NAND 500GB
♦ DSP - LG 27" 4K UHD FreeSync Gaming Monitor (27UD59P-B.AUS)
♦ PSU - Antec High Current Pro 1200W
EDIT:
Added CPU test and memory test for anyone interested
Memory speed 1080 vs 1440
High Infinity fabric clock-1867Mhz
Deus Ex Mankind Divided Ryzen CPU Test 3600Mhz vs 3800Mhz vs 4400Mhz
Video of all three resolutions tested one after another no breaks/restarts
Msi Afterburner Raw data 3600Mhz
19-08-2019, 18:58:10 DXMD.exe benchmark completed, 10221 frames rendered in 91.672 s
Average framerate : 111.4 FPS
Minimum framerate : 89.1 FPS
Maximum framerate : 143.3 FPS
1% low framerate : 88.5 FPS
0.1% low framerate : 83.3 FPS
Msi Afterburner Raw data 3800Mhz
Average framerate : 109.7 FPS
Minimum framerate : 86.6 FPS
Maximum framerate : 141.8 FPS
1% low framerate : 86.3 FPS
0.1% low framerate : 83.6 FPS
Msi Afterburner Raw data 4400Mhz
19-08-2019, 19:00:51 DXMD.exe benchmark completed, 10227 frames rendered in 93.046 s
Average framerate : 109.9 FPS
Minimum framerate : 86.5 FPS
Maximum framerate : 141.9 FPS
0.1% low framerate : 82.7 FPS
19-08-2019, 19:03:29 DXMD.exe benchmark completed, 10234 frames rendered in 93.266 s
COMPUTER USED
EDIT:
but the boosting on my chip does boost higher though in games 4.44ghz at stock which is actually a few frames better on my gpu. But my max temps are about the same in games about 80 degrees give or take. But my idle temps are high 50s for either oc or stock on my x570 c8h mobo.
