- 17 Sep 2006
- Gloucestershire
Fixed
You can barely use 340hp on many roads, I can't imagine why you'd need another 100!
Fixed
Hardly surprising when you consider the £/performance gain. I could get my 140 mapped for £600, which will give another 100hp!
I remember back in the day of owning a Clio 182, a set of throttle bodies were around £2k, and you'd be lucky to get more than 20hp!
Did they say whether they flat out refused warranties on them or how they proved the map? It would be an interesting dilemma if you managed to buy something Approved Used which had been mapped!
I don’t think VW will sell one second hand so it would be a 3rd party dealer you would buy it from.
If it has a TD1 flag against the car any driveline warranty claims would be rejected.
If I was doing mine I would seriously consider one of the ones where they physically replace the "chip", its not that much more expensive and means you have your original ready to swap back in should you need it.
ABT do a plug in system that looks pretty good, but it's a lot more expensive than a remap. A stage one for my car is £1,500 (252ps increased to 316ps). ABT are also doing the Seat approved upgrade for some Cupras so I imagine that know what they are doing, you'd hope.
I've concluded I'll just buy a faster car next year with warranty.
6hra into a 7hr journey from Nottingham to Lancaster and my Golf R
Nottingham to Lancaster takes 7 hours?
I got held up around Stoke and at numerous roadworks. Think it was 3hrs 30 there and 2hrs 30 back, so maybe 6hrs rather than 7
so you had RAC cover via VAG ?, and after you travelled to non-helpful dealer, next day, then had to call them again to move it ... convoluted process.
When mine showed that error it needed an new gearbox including clutch packs. That was 15k miles ago. Just lucky it is still under warranty.
Whilst it's in there I've asked them to review the exhaust system as the tips are corroded to the point its flaked off and pitted, see if they can warranty that as well whilst it's there!
Should have got the Titanium one!
Out of interest, have you used the launch control much? I've only tried it a few times in mine, but the up changes are certainly a lot more brutal than even in sport mode. Can't be too good for the box.
Scary too think how much this would cost someone if the car was out of warranty..Yep, just had the call from the dealership and the gearbox and clutch pack have been ordered, arrival expected after bank holiday weekend, so keeping the R-line for another week.
And it even more scary seeing that a 2 year old car needs a new gearbox already![]()
I believe ABT modifications do not affect your warranty on certain models, certainly on the continent in any case. They are very well respected.Yeah think it was ABT I was looking at as well. IIRC they also do an insurance policy alongside so whilst its a lot more expensive than some others its not like for like.
Don't think that arrangement extends to the UK.I believe ABT modifications do not affect your warranty on certain models, certainly on the continent in any case. They are very well respected.
ABT Sportsline offers the best warranty solution on the market with 2 years warranty up to 100.000 km from the date of the first registration. The warranty will be offered in following countries: Germany, Austria, Netherlands, Belgium, Luxembourg, Sweden, Norway, Denmark, Finland, Italy and Poland.
