Hi All,
Looking to get into some pc gaming in the very near future and am looking for some advise.
I have already bought the ram and local memory as it was on a good sale on amazon. In hindsight I should have probably did a bit more research on the ram to make sure it was sufficient for what I needed.
As for my budget, for the pc alone I am looking at between €1000-€1500. I do not need the best of the best equipment, I am after a good value build which will play games. Of the games my intention is to play pubg, preferably at a high res (1440) and high frames (144), so please consider this when given advice.
I have been reading a couple of builds, searching forums, comparing parts and Ryzen CPU and 5700xt GPU have caught my eye with their bang for buck.
Ok, so this is what I have:
Ram: Corsair Vengeance LPX DDR4 2x8gb 3000mhz
Memory: Corsair MP510 NVMe PCIe Gen3 M.2 SSD
What CPU, GPU, MBO, power supply and case would people recommend to achieve my goal?
Thanks.
Thanks.
 Luckily your link was starred out.
