^^^ and that's why you post in here! Most of us would be looking at components and general wear of them, as we wouldn't have direct experience of those frames. But an insight from someone who's ridden and worked on those is invaluable!
The Felt is no longer showing, so looking at the Scott I'd be questioning why it's had new wheels and why they chose very average Giant wheels. The SR1 are a 'sport' wheelset from their lower range endurance bikes. Bombproof and headvy. Cup & cone bearings (no bad thing on cheap wheels) but high spoke count and cheap, heavy hubs. A £100-150 set of Fulcrums/Prime/Campagnolo would be loads better. I'm betting they came off a new bike which replaced this one (not a bad thing as means low mileage)...
It has old 105 and old Ultegra so it's only 10 speed. Saddle looks like it needs replacing and Jonny is right about that seatpost. Closeup does look like it's never been moved. Thinking about it, the saddle has a weird angle as if someones been riding it nose down like that to drop the height a little as they can't get the seatpost down...!
designing flaws in from the start seems to be the in thing now.
i've half an eye on a planet x pro carbon evo disc for just this reason...
So you're buying an open mould frame with questionable provenance?
On that note...
I'm considering whether to upgrade (my Planet X London Road) and my current preference would be the Planet X Pro Carbon Evo Disc R8000 which I'd then upgrade with a £300ish replacement wheelset (maybe Hunts).
Is this a sensible way to spend £2k?
My wants list is really just discs, short seat stays (purely aesthetics), internal cable routing.
For £2k yes, it's probably the only way to get a carbon frame, R8000 and a quality wheelset. If those are your requirements.
Anyone wanting a Shimano 36/52 chainset to fit or put in spares box? Black 172.5mm version at least is £64
https://www.evanscycles.com/shimano-105-r7000-road-chainset-52-36-EV336880
Great price! I've spent double that on bearings and BB's the last few months.
@Roady you just need a standard BB tool to tighten up that WheelsMfg BB, same as you’d use to install a normal HT2 cup. It’s the BB86 one that needs a specific tool IIRC.
Oh, I bought the wheelsmfg tool as I don't have the HT2 cup one anyway... Well may have one in a no-name/unbranded budget cycle toolkit from a PX deal...
What he said ^ same for a praxis one I did today. Hollow tech tool.
The Praxis one I bought for the Praxis M30 BB I previously had, is a different fitting to the wheelsmfg BB.
Thanks, it went great. Turns out I was
fastest of the 50km riders by a good 7 minutes. I realise serious riders would be doing 100km or 150km, so next one perhaps 100km for me...
Good work. Great average considering your first!
