Thanks mate appreciate it, I've asked around but nobody has an old ryzen they are either Intel or older amds like the f.
I can flash it for you, if you are anywhere near me.
Thanks for the offer mate really appreciate that but already boxed it ready to send back.I can flash it for you, if you are anywhere near me.![]()
Thanks for everyone's help I've now ordered the msi tomahawk and boxed up the asus b450 board.. Fingers crossed its all plain sailing now.
Much appreciated![]()
You've bought the MAX version, right?
Because there's a MAX version (with 32MB EEPROM and supporting 3rd gen Ryzen out of the box) and a non-MAX version (16MB EEPROM and would need a BIOS update first).Yes the max. Why do you ask?
Yes, the MAX version is the one you want.So to confirm I am doing right by ordering a tomohawk max aren't I?
PhewwwwwBecause there's a MAX version (with 32MB EEPROM and supporting 3rd gen Ryzen out of the box) and a non-MAX version (16MB EEPROM and would need a BIOS update first).
Non-MAX Tomahawk wouldn't have been much of problem.Phewwwww
Almost all MSI's B450 boards have hardware routine for flashing BIOS from USB with only board and PSU:
That should be common feature in motherboards.
But instead marketroids waste money to fashion trash and RGB gimmicks.
All of them have their fair share of good and terrible motherboards.Who are considered the best brand for motherboards nowadays? MSI?
When I bought mine gigabyte and asus were arguably the best apparnently but know things change.
Like Buildzoid has said it, they all suck in something and have had and will have trash products occasionally.Who are considered the best brand for motherboards nowadays? MSI?
For example in B450/X470 Asus and Gigabyte had many boards with the worst CPU VRMs good only for 65W TDP CPUs.
Now even the cheapest Asus X570 board has VRM good for coming 16 core.
Also except for Gaming X Gigabyte has good VRMs in their X570 boards.
MSI again had overall the best VRMs of B450. (Gaming Plus/Tomahawk/Carbon)
But they copypasted same VRM components into lower X570 boards, making those crap compared to Asus and Gigabyte lower end and you need to pay arm and leg to get good VRM MSI X570 board.
Also ASRock uses some very cheap component VRMs in three lowest boards making you pay more for modern VRM board
Both Gigabyte and MSI have now BIOS Flashback as standard feature in all X570 boards...
While ASRock and Asus make you pay arm and leg for that.
Or say you want two USB3 headers for four USB3 ports in front of the case?
All Gigabyte and MSI boards have two USB3 headers, but Asus?
Only the cheapest Prime X570-P has that. Unless counting in buttrape, murder and robbery priced Crosshair Formula!
Also common in ASRocks, except for Taichi which is the cheapest ASRock with modern VRM!
In short:
Don't trust brand and marketing to mean that you actually get features price sticker should give.
Enabling PBO is pretty much the most sensible approach.Are the 3600 overclock able and if so is it worth it? I read people getting them upto 4. 1ghz but said they weren't really worth the hassle? Just thinking of a few years down the road if my son wants to overclock it?
Asus Prime X570-P or Gigabyte X570 Aorus Elite have modern high efficiency VRM with integrated power stages.I wish they made boards with just the high spec VRM's but without all teh extra 10GB lan, wifi and loads of stuff I don't need.
