- 22 Jul 2012
- London
NoobHe's right its so limiting, its horrible to play with no freedom to move about and magnetic walls. You can't even jump and its a shooter.
What driver you running. Was running the 388. Because it was the one that ran Forza 7 the smoothest. but wouldn't run this game. So I've tried these so far but still freezers. 431.70.. 436.15.. 436.30
Does this game have split screen coop on PC?
I had a couple of OOM crashes today so had a look into it. This game is a mental resource hog.
During campaign on ultra, it was using over 9GB of RAM and around 7.2GB of VRAM. It seems using the insane shadow setting might push the VRAM a bit too far on 8GB cards. Once I closed down a few programs and switched from insane to ultra, it’s been fine. It seems an 11GB card is optimal if you want to run everything at max.
One thing to note, this also started after I installed the texture pack. I don’t know if the textures use VRAM too, but it could explain the huge amount of VRAM being used.
Im using a gtx 1080 which is 8gb vram and i'm not having that issue. I'm only running at 1080P, are you at a higher resolution? I only get an average of 90fps though, thats with everything maxed (apart from motion blur, that can stay on a consoleI had a couple of OOM crashes today so had a look into it. This game is a mental resource hog.
I’m at 1440p.Im using a gtx 1080 which is 8gb vram and i'm not having that issue. I'm only running at 1080P, are you at a higher resolution? I only get an average of 90fps though, thats with everything maxed (apart from motion blur, that can stay on a console). Maybe its an amd issue rather than a vram issue.
Might have found a reason for my out of memory crashes.
Can I ask if having absolutely no hard drive space left can cause games to crash? It's just crashed with an out of memory message just as it was saving to disk after reaching a checkpoint. When I was back at desktop, the windows manage storage popup appeared.
Yep. The system does appear to have slowed down as well. I reckon that’s definitely what’s causing the out of memory crashes, because it’s crashing when saving checkpoints.Definitely, it can cause stutters and slowdown with normal desktop activities too. I'm assuming it's the drive where windows is installed?
I need to learn to keep to the 10% rule.
I’m gonna add a 1TB Nvme drive and clone my 500GB current drive to it. Just waiting for prices to drop slightly. Samsung’s are still around £200.I use the multiple drive rule![]()
Are you running latest versions of windows and the app?I can't even launch the game now, Every time I click play it runs through some windows prompts and then just throws up a "Please check windows store" message. Anyone have any solutions?
