The AMD Driver Thread
AMD Adrenalin v19.9.1 Released.
Radeon Software Adrenalin 2019 Edition 19.9.1 Highlights
Support For
  • Gears 5™
    • Up to 8% performance improvement in Gears of War 5 running DirectX® 12 on Radeon Software Adrenalin 2019 Edition version 19.9.1 vs. 19.8.2.RS-310
Added Vulkan™ Support
  • VK_AMD_device_coherent_memory
    • This extension adds device coherent and device uncached memory types. Device coherent and uncached memory are expected to have lower performance for general access than non-device coherent memory but can be useful in certain scenarios particularly so for debugging.
  • VK_EXT_calibrated_timestamps
    • This extension provides an interface to query calibrated timestamps obtained quasi simultaneously from two time domains such as host and device time domains.
  • VK_EXT_line_rasterization
    • This extension adds some line rasterization features that are commonly used in CAD applications and that are supported in other APIs like OpenGL. These features include Bresenham-style line rasterization, smooth rectangular lines (coverage to alpha) and stippled lines for all three line rasterization modes.
  • VK_EXT_shader_demote_to_helper_invocation
    • This extension adds Vulkan support for the SPV_EXT_demote_to_helper_invocation SPIR-V extension. The SPIR-V extension provides a new instruction that allows shaders to "demote" a fragment shader invocation to behave like a helper invocation for its duration. The demoted invocation will have no further side effects and will not output to the framebuffer but remains active and can participate in computing derivatives and in subgroup operations. This is a better match for the "discard" instruction in HLSL.
Fixed Issues
  • Launching RGB Fusion 2.0 may cause a system hang on Radeon RX 5700 series graphics products system configurations.
Known Issues
  • Gears 5 may experience an application hang on loading screen with APU only (Ryzen) based desktop system configurations.
  • HDMI® overscan and underscan options may be missing from Radeon Settings on AMD Radeon VII system configurations when the primary display is set to 60hz.
  • Stutter may be experienced when Radeon FreeSync is enabled on 240hz refresh displays with Radeon RX 5700 series graphics products.
  • Radeon Performance Metrics may report incorrect VRAM utilization.
  • AMD Radeon VII may experience elevated memory clocks at idle or on desktop.
  • Radeon Overlay may intermittently fail to appear when toggled in game.
  • Audio for clips captured by Radeon ReLive may be corrupted or garbled when desktop recording is enabled.
  • Enabling Enhanced Sync may cause game, application or system crashes on Radeon RX 5700 series graphics products.
Footnotes
  • RS-310 - Testing conducted by AMD Performance Labs as of August 30th, 2019 on Gears of War 5 (DirectX® 12 at Ultra Presets) at 4K resolution, measured on the Radeon™ RX 5700 XT running Radeon Software Adrenalin 2019 Edition 19.8.2 and 19.9.1 drivers. Results on 19.9.1 showed up to 8% performance gain over the previous driver. Performance may vary based on resolution and settings.
What HDR issues you having? my HDR TV working fine
https://gyazo.com/f6e45be04ee2fbe742baebcac859ce05 <- this
And here's an example on HDR that does activate.. Left being on right being off, Same thing happens ingame. https://gyazo.com/0e2a411a646d14cb161962fffc8cb7d0
Only thing that changed in my pc was installing the 5700xt, I ddu'ed the drivers before and installed the new ones, Everything was fine before.
Side small issue but some games now have stutter when playing like it's having issues with shader caches.. Going to throw that one down as driver stuff, Not a huge issue since it goes away after playing.
Radeon Software Adrenalin 2019 Edition 19.9.2 Highlights
Support For
  • Borderlands 3
    • Up to 16 % FPS improvement on the Radeon™ RX 5700 graphics card running Radeon™ Software Adrenalin 2019 Edition version 19.9.2 vs. 19.9.1 drivers.RS-312
  • Radeon Image Sharpening
    • Now available on Radeon RX 590, Radeon RX 580, Radeon RX 570, Radeon RX 480 and Radeon RX 470 series desktop graphics products for DirectX®12 and Vulkan® applications.
Fixed Issues
  • With v-sync enabled FPS may be locked to 30 on some displays set to 75hz refresh rates.
  • System instability may be experienced on some Radeon RX 5700 series graphics system configurations when watching video content in a web browser.
  • Radeon Settings may list core clocks as not available with some Radeon RX 5700 series graphics system configurations.
Known Issues
  • Sekiro: Shadows Die Twice™ may exhibit texture corruption during later parts of the game.
  • Toggling HDR may cause system instability during gaming when Radeon ReLive is enabled.
  • Discord™ may experience an application hang on Radeon RX 5700 series graphics products when HW acceleration is enabled.
  • Display artifacts may be experienced on some 75hz display configurations on Radeon RX 5700 series graphics system configurations.
  • Call of Duty®: Black Ops 4 may experience stutter on some system configurations.
  • Open Broadcasting Software™ may experience frame drops or stutter when using AMF encoding on some system configurations.
Footnotes
  • RS-312 - Testing conducted by AMD Performance Labs as of September 12th, 2019 on Borderlands 3 (DirectX® 12 at ‘Badass’ Presets) at 1080p resolution. Performance may vary based on resolution and settings.
Important Notes
  • AMD Ryzen™ Mobile Processors with Radeon™ Vega Graphics FAQ for Radeon Software Adrenalin 2019 Edition can be found here.
hopefully 19.9.2 fix the bloody random crashes that 19.9.1 have caused, been rock solid until 19.9.1 with vega64 and yes hardware acceleration is disabled in all browsers./
Hey all,
Can anyone with a Navi 5700XT & Dirt Rally 2.0 check if they get the same judder issue when trying to record with Radeon Relive please, I have Relive set to 75mbps but I don't think that actually matters.
