Man of Honour
- 21 Nov 2004
So after reading this thread and some reviews on youtube I went for the AutoGlym Polar range. I have a big car (Citroen Spacetourer) and it was a delight to wash and far quicker than previous efforts. Very simple application:
Polar Blast coat all over using snow foam lance and pressure washer.
Rinse out snow foam bottle and prepare the Polar Wash solution.
Give it another 5 minutes and then rinse off the snow foam.
Polar wash on two sides of the car - if your car is small and/or its not in sun you could do your whole car.
Microfibre mit straight onto to the car and use the layer of polar wash to clean.
I had a clean rinse bucket which was used to rinse the mit every not and then.
Pressure wash off and move to the other two sides and repeat.
Once the car was clean and rinsed. I made up the polar seal solution and applied over the car - avoiding the front windscreen.
Tool about 30 minutes including the time to clean the wheels and tyres. Got to be honest I was a little skeptical, but so impressed with the quality of the finish for the little effort required.
Another convert
That’s the real benefit isn’t it, the quality of the finish for so little input. As others have said, it’ll be even better in the winter when you want to spend as little time as possible outside washing the car.
The only change I am planning to this regime is to use bilt hamber auto foam instead of polar blast (once it’s used up).
All of these products do many washes too, I’ve used hardly any of the polar seal.
I quite often use autoglym rapid retailer afterwards too with a micro fibre cloth for any small marks left on the car e.g. the off fly, spot of tar etc.
