Installed my new hardware. Do i select reset this pc?
18 Oct 2002
Newcastle, England
Ive upgraded my motherboard and cpu and ram. In windows 10 do i select reset this pc to do a fresh install. As i want rid of all the old motherboards drivers ect.
Is a fresh install only viable from removable media? I haven't an 8 gig usb drive to hand or disc. Anyhow ill give it a try.
The easiest method would be to use a spare USB stick. All the contents of the USB stick will be wiped, so make sure there's no data on it that you need. Maybe you can try to borrow one from someone else?
Yeah for now ive just done a reset of pc wiping all the files. I have to say its all running very sweet though. Im very pleased with it all. Had a few problems re activating windows but its solved and its all go. Just a pain re installing game pass games, i cant wait to try out Gears of war 5 to see what this baby can do. :D I'll make sure though I do pick up a usb key for future. :)
It sounds like you used windows to go back to a fresh install and it took your old key which saved you $100 so yay you. Reinstalling games is a small loss but at least they are I assume on a ssd and not all over an old hdd.
Fresh install is the correct answer. A "refresh" will generally keep the drivers.
I did a refresh moving from Ryzen to Intel and it managed to keep the Ryzen power plan so I would absolutely say a fresh install would be better.
