ASROCK X570 TAICHI - THE RYZEN 3000 MOTHERBOARD GIBBO & 8 PACK RECOMMENDS
24 Sep 2013
Exmouth, Devon
HWinfo have 4/8 cores at 4.6 of which one at 4.625 Rest are at 4.55 except one at 4.525 Gonna game on it later so 4.4Ghz all round hopefully as it was 4.350 all core playing PUBG. So all cores will boost to 4.5Ghz+ just not all at the same time obviously. Hard multi-threaded test/bench/stress still only 4.2Ghz max all core.
STILL not drawing more than 70W :confused:
22 Nov 2009
Under the hot sun.
What are your temps? Also have you set VDDG to 1.1?
Caporegime
8 Jan 2004
Rutland
Actually seeing boosts above 4.4ghz on my 3700X, peak is 4.45, never saw anything like that previously.
Probably for nanoseconds and irrelevant in the real work but still something seems to have changed.
24 Sep 2013
Exmouth, Devon
Hmm yeah 86 degrees under a bench test but the load on the CPU when gaming isn't big in anyway. It's 65 degrees playing PUBG in Afterburner showing all cores at 4.35
Have SOC set to 1.1 but rest is auto...I think....god I've messed about with it so much a while back I need to check...
Right Apart from RAM timings manually entered and RAM voltage @1.4v,
[email protected]
[email protected]
SOC @ 1.1
