Think I'll stick with 2.00 for now until it's out of beta, never noticed my system underperforming so ignorance is bliss![]()
HWinfo have 4/8 cores at 4.6 of which one at 4.625 Rest are at 4.55 except one at 4.525 Gonna game on it later so 4.4Ghz all round hopefully as it was 4.350 all core playing PUBG. So all cores will boost to 4.5Ghz+ just not all at the same time obviously. Hard multi-threaded test/bench/stress still only 4.2Ghz max all core.
STILL not drawing more than 70W![]()
I've never seen my 3700x go over 4.2 in Ryzen Master.
I thought the that was the point of PBO.
What are your temps? Also have you set VDDG to 1.1?
Corsair 3466mhz 16GB sticks. Currently using only 2 as they wouldn't go above 3000mhz with 4 fitted.
Whats the exact kit please to check it's full data?
How do I ensure PBO is off on this board?Don't use PBO. Basically use nothing if you want the CPU to boost properly.
