EVGA aside, you won't find a vendor that is clear on the matter.
Here's an excerpt from the AMD warranty (sorry for the caps, but I'm not rewriting it):
So if they suspect you caused damage, you're on your own. Arguing that "the product" refers to the PCB only is a non-starter; that would mean the cooler doesn't constitute part of the product, and isn't covered by warranty, which is clearly ridiculous.
THIS LIMITED WARRANTY SHALL NOT APPLY TO YOUR PRODUCT IF AMD DETERMINES IN ITS SOLE DISCRETION THAT THE ALLEGED FAILURE OF THE PRODUCT TO MATERIALLY CONFORM TO THE SPECIFICATIONS DOES NOT EXIST OR WAS CAUSED BY, RELATED TO OR AROSE OUT OF[...] UNAUTHORISED ATTEMPTS TO OPEN, ALTER OR MODIFY THE PRODUCT
