Got water under my floorboards and found this.
OP
30 Aug 2003
What is the floor construction?
If suspended timber, check external ground levels
. Yes it’s suspended, I live half way down a hill in a terraced house, so water table levels shouldn’t be an issue? And air bricks are above ground level.
How much water are we talking here?
originally when I first opened up the floor I removed over 200 litres of water and it slower replaces itself.
I have opened up more of my floor and now have the thing outhttps://photos.app.goo.gl/sTyFuiGj8mzUnrhA8
https://photos.app.goo.gl/d92pBDxiVbkPSwji7
OP
30 Aug 2003
Looks like an old water meter maybe? Google the name on it. Doubt its related if it was just loose in the rubble/ground
Yes, just left lying there, on original siting I couldn’t tell if it was connected.
No numbers on it for it to be a meter, it’s been suggested to me it could be an old central heating pump.
I couldn’t decipher what it’s name etc was.
20 May 2009
It does look like a central heating pump.
Definitely an old pump.
No idea how you'd get that much water under the floor without noticing.
Do you have a water meter in the path? Make sure your taps are off and see if the water meter spins, there's a little star on them which is very sensitive to flow so it should be noticeable.
OP
30 Aug 2003
I only bought the house recently and been trying to sort a damp issue, so by process of elimination I have arrived at this point.
No water meter it’s an 1893 mid terraced house.
The water is localised to the one room.
Got a plumber coming out on Saturday, so hopefully he can sort something.
1 Mar 2008
Deep North
I agree it could be an old central heating pump. My floorboards are suspended too and I know for a fact that the old pump from the old solid fuel central heating is still under there. The central heating bods just by-passed it and popped the floorboard back down. In fact it's still connected to the switch on the wall and makes a funny noise if I switch it on :p
25 Jan 2003
I found water under my suspended floor and found that after heavy rain water was seeping in round a waste pipe that had been punched through the wall below ground level. I basically dug out outside and improved the drainage.
21 Jan 2008
Cotswolds
It might be an old water meter, I have one in a building we own at work, however, it's unlikely to be connected (how would you read it under the floor?!?) and the same goes for a pump, why put it there making access a problem to repair!
200 litres is a lot. It's probably one of these:
1. Leaking incoming mains (you've mentioned 1893) so more than likely part of the supply pipe, if not all, is lead. Could have gone.
2. Waste pipe somewhere cracked and leaking in there - sink/shower/bath etc.
3. Source from outside, via air bricks or damage
Hopefully the plumber will trace the leak! Let us know!
