- 20 May 2019
- London
It's like talking to a wall.
I think the assumption that AMD = Cheap is for bulldozer days, it might be cheap for what it is but the performance is there and your buying into a platform where small "cheap" £60 cpu upgrades are even worthwhile. Tell a man that paid £1000 or even £4000 for a cpu made by AMD that it's the cheap option. Other than that you literally have just told the entire world what they already know.
So just to recap, don't buy new CPU's because older slower ones cost less? Thanks for this incredible nostradamus level of insight.
The performance has been there since the first generation of Ryzen. With third generation Ryzen, AMD only managed to equal i9-9900K performance.
Meanwhile, we had expected price reduction because of the new manufacturing node. Price reductions didn't follow - actually the opposite has happened - price increases.
I think he only means to buy those CPUs with best performance/dollar.
Well clearly majority responding here are with big pockets and on the bleeding edge of the technology, so much so, that the mere musing of buying second hand sounds like an insult.
But everyday there's several new threads from people with limited budgets of around 700 GBP that are after capable systems that might find this thread useful. When you are that heavily limited by the budget a second hand 2600 for 80 GBP will go a lot further than 3600 for 180 or whatever is its price, while being not that far off in performance spectrum.
And its not like you have to sacrifice anything. In a year when 4600 comes out, just swap your 2600 for 3600.
Again, you’re not saying anything new here buddy. I’ve seen quite a few threads where people looking for budget focused builds have need advised to go 2600 with a b350 or b450 board.Well clearly majority responding here are with big pockets and on the bleeding edge of the technology, so much so, that the mere musing of buying second hand sounds like an insult.
i say look at own spending before giving advioce on staying behind the curve but hey thats just me
AMD have equalled in gaming and trounced the 9900K in productivity at a similar price point (after Intel shaved £100 off the price).
Price reductions didn't follow? How much was a 12 core CPU from Intel or on X399 before the 3900X came along? How much was a 9900K at release of the 3900X? Zen 2 seems to have been pretty good value to me right across the board.
I'll entertain you. Technically since AMD just autoboosts and doesn't overclock. AMD fanboys have nothing to do on "overclockers" forum. you need to form a new forum like, "barelyboosts dot com or itcomeslikethisfromthebox com"
Lol to be fair Intel are just as guilty of killing off overclocking but only as a close second to Nvidia. Nvidia overclocking died with Maxwell.
I'm astounded. Going by your calculation a second hand 2600 will cost £80 now then spend another £80 in a year on a 3600.Well clearly majority responding here are with big pockets and on the bleeding edge of the technology, so much so, that the mere musing of buying second hand sounds like an insult.
