Mine arrived yesterday and has survived the journey just fine. Only had a few hours last night but a few pointers that might prove useful (or prove I'm an idiot
- the thumb screws that lock the rear drive cages in (the internal one, not the cover) are not captive. Don't unscrew it too far or you'll spend 15 minutes refitting the screw and retaining mechanism.
- the GPU support bracket does rest on the chipset heatsink/fan on my X570 Arous Pro, but does not obstruct the fan from turning. Not got a GPU in there yet, but it does seem to be a really nice solution.
- a single bag of screws is provided with 6(?) different sizes in there, well worth sorting them before you begin.
- the rear cable cover is held in place with 4 screws, not 6 as I first thought. The two screws at the very top hold the clip mechanism and don't need to be removed. Careful with these screws, they are very small and could easily get chewed up.
- the ROG label does appear to be etched into the glass on my case, but I've not removed the glass protection sheet to check properly so I might be wrong on that.
