Will be buying a new TV for my dad come November, figured I'd upgrade his audio as well. Currently he has an £8 pair of headphones plugged into a 5 meter extension cable into the 3.5mm socket on the TV. It does not work well.
I am struggling to decide on the best option.
He is hard of hearing, which is why he uses headphones. He watches Sky HD only, he doesn't have a DVD player etc. The priority is clarity at higher sound levels.
The option I am thinking (if they even work?) is:
Anyone have any suggestions? Budget around £100 - 150
If I don't need a DAC, I assume something like a Schiit Magni3 would do the job and would there be any notable slightly cheaper options?
I know nothing about audio stuff sadly.
Cheers.
- Either optical or rca from the new TV into an amp/dac under the TV, then running a headphone extension cable in the pre existing trunking which comes out next to where he sits. Then he can plug the headphone in and not have the cable trailing on the floor.
Cheers.
