Advice needed, GPU full of white rust???
4 Oct 2019
Hi all,
Need some advice/help if you can. I have a GPU that I was using and then left it in the shed in the garden, sadly exposed to the air as I had the window slightly left open since I have been away for a few months on work. I have back to seeing some white crusty stuff that has accumulated on the GPU fins (please see pictures attached on the link from different angles).
I have tried to use an ear bud with nail varnish remover to take it off but it doesn't seem to go away and can't get the buds in to the fins properly.
Can anyone suggest what I can do to remove this and what it potentially is?
Any help would be much appreciated, thanks
https://~ibb.co~/jg2mMHm
https://~ibb.co~/XLVM5GT
https://~ibb.co~/zxwGVG5
https://~ibb.co~/vdkLXdV
Looks like mould?
Get yourself some pure Isopropyl alcohol from eBay and a soft hobby brush, take the card apart and give it a good clean, once clean and fully dry, reassemble and see if it still works? :)
ive seen similar build up on customers machines who are smokers, the tar sticks on the outer edges of heatsinks and fans then then dust get stuck to it and goes a similar colour overtime, your not a smoker are you?
Looks like mould?
It’s mould, would alcohol remove it?
Op do not use any type of mould killer or cillit bang. it’ll strip the anodizing, a new layer of oxide will form but it will look crusty. Unless you want to diy anodize it
Hi all,
Dust mixed with dew. Just clean it up. Also what the GPU was doing in the garden shed?
Iv already planned my stages.
Delivery, behind the sofa, under dining table, in a bag on the coat peg, under bed then finally in pc.
Just hope the box isn’t too big
hahaha.... something like that.
Would it be ok if I let it be soaked in Isopropyl alcohol for a few minutes and then try and scrub it off? Or don't soak it all but try and scrub it with a brush that I dip in the Isopropyl solution?
Dismount the heatsink from the GPU and remove the fan before you try anything.
I'd dunk the heatsink in water and attack it with something like a toothbrush. If that doesn't work then use a weak acid like spirit vinegar. Once clean, rinse the heatsink in isopropyl alcohol to displace the water and dry. Aluminium shouldn't require 'sealing' or anything as it forms a self-insulating layer of aluminium oxide on contact with air.
In normal use this might be true, and the process is called anodising, but it isn't thick enough to resist the hostile environment this card has been stored in. https://en.wikipedia.org/wiki/Anodizing
If you use water then boiled (and cooled) de-ionised or distilled water and look up all the sites in cleaning these things before you do.
I soaked aluminium in iso once, It stained it white i threw it out because i was not sure what i done but before it went in the iso long term it never had the white stains hmm.
Test it first I don’t know if alcohol will strip the anodizing. I haven’t tried it so I don’t know, I do know that cillit bang will strip anodizing so don’t use that.
