Thanks. Did you just take 5v DC from the GPIO?
RTL SDR v3 and LNA arrived. Had to mutilate the ADSB Reciever Project installation scripts a fair bit to get around a few obstacles on Buster.
Can detect aircraft for around 10 mins. After that the GUI shows an error that dump 1090 is no longer running and the Pi goes unresponsive on SSH.
Was using the bias tee on the dongle for now. Deactivated it and took the LNA out of the loop. Same symptoms. rtl_test detects the dongle ok.
Might start all over again and load Jessie. If it persists I guess there is a hardware issue.
