If you want more performance then you’re starting to get a bit more expensive and the law of diminishing returns comes into effect. The next step up is to buy a separate receiver and amplifier. If you want to do this then my recommendation is the
RTL-SDR V3 dongle and the
RTL-SDR 1090MHz LNA at $21.95 and $26.95 respectively and available from the
RTL-SDR shop. These will take a couple of weeks to be delivered to the UK and you’ll also need to buy a
bias-tee module as well which will add another tenner or so to the cost and further complicate the build.
