This is interesting, I really had to look for a video with result I could compare too.
Test Bench: Intel 9900k Processor Overclocked to 5.0ghz All Cores No AVX Offset (1.27V)
Corsair H150i PRO 47.3 CFM Liquid CPU Cooler (Fans @ 100%)
Asus ROG STRIX Z390-E GAMING ATX LGA1151 Motherboard
Corsair Dominator Platinum RGB 16 GB (2 x 8 GB) DDR4-3200 Memory (16-18-18-36?)
Samsung 970 Evo 250 GB
M.2-2280 SSD (Boot)
Samsung 850 EVO 250 GB 2.5" SSD (Games)
Asus ROG Strix RTX 2080 OC Edition (GPU Boost Clock @ 1970MHz)
Corsair RMx 650W Power Supply Corsair 750D Airflow Edition Case
Benchmark Tool. Results:
Average Framerate (99th percentile): 64.45 Max.
Framerate (99th percentile): 93.17 Min.
Framerate (99th percentile): 38.37
Settings: DirectX: DX12 Resolution: 1920x1080p Quality: Ultra Texture Filtering: AF 16X Motion Blur: Normal Tesselation: Full Advanced PhysX: On Hairworks: On Ray Trace: Ultra DLSS: Off Shading Rate: 100%
Using 100% the same settings on my system.
AMD Ryzen 7 3800x PBO auto OC +200MHz (PBO limits auto) Scalar x1
ASRock X570 Taichi
NVIDIA GeForce RTX 2080
Team Group Inc. 8192 MB (DDR4-2400) - XMP 2.0 - P/N: TEAMGROUP-UD4-3600
(16-15-15-31-46-1 (tCAS-tRC-tRP-tRAS-tCS-tCR) 1899.6 MHz (DDR4-3800) Uncore: 1899.6 MHz)
Full custom water loop 360 rad and full copper block. push/pull fans.
Corsair AX1000
https://i.~ibb.co~/R21qMd2/metro-exodus-RTX-test.gif
Would appear to be equal or GPU limited.
M.2-2280 SSD (Boot)
ASRock X570 Taichi
Corsair AX1000
- Average Framerate (99th percentile): 64.88
- Max. Framerate (99th percentile): 89.26
- Min. Framerate (99th percentile): 38.37
