- 20 Aug 2019
Anyone here got experience of using one of these? I've just gotten hold of one via work.
Yes lots. What do you want to know?
Not a lot. Just need to make sure you set the APN's up and you should be away. MikroTik kit is a bit of a learning curve if you haven't used it before. The webfig quickset menu will just about scrape you to a working config but there is SO much more.How much setting up does it require? Found nothing really showing or explaining. It's got dual sim and we have a vodafone and EE we'd like to use.
Correct.Dual SIM but not dual radio IIRC
I'm stuck for setting the APN's up.
I've done a few Mikrtoik but this is really giving me the run around
What service providers are you using? Most of the APN information is freely available on the internet.
Yes, you can specify which SIM you want to use as the primary. The other one can be set up as the failover.
EE is
APN: everywhere
Proxy: Not Required
Port: Not Required
Username: eesecure or not required
Password: secure or not required
Vodafone is
APN: internet
Proxy: Leave in Blank
Port: Leave in Blank
Username: web or not required
Password: web or not required
Did it self populate like that or did you type it in?
I suspect you typed it in. Try the vanilla EE settings I posted. It’s always worked for me.
Is there something I’m missing for the sim car selection to which APN that is?
And which interface are you using currently? You shouldn’t still have a default LTE interface if you started off with Quickset.
How did you get to this point?
You may be better off doing a complete reset and rebuilding the list. Quickset gets you up and running. After that you’re best downloading Winbox which gives you ALL the exposed options.
That’s using the CLI option via SSHExample here is for the LTAP but should be easily changed for the SXT kit:
https://wiki.mikrotik.com/wiki/Dual_SIM_Application
Obviously this is after you have EE working.
