Ideal combi boiler (vogue)
18 Feb 2007
London
Hi
Had a Ideal combi bolier (vogue gen 2) the vogue max to be precise but its the same boiler I believe.
Just wondered from other's that have this boiler on how loud it is?
I read that it has been awarded the quiet mark, but on Ideal I can't see that mentioned for this boiler, If it has got it I would not say its quiet, if I run hot water, I can hear the boiler running, its slightly more quiet when the central heating is on.
Just wanted others feedback on how they find the noise levels?
18 Oct 2002
Leeds
In a word, very! I recently moved into a house with one of these boilers, and even though it's in a boiler house, essentially hung on what would have been the external wall of the house, I can hear it fire up at the opposite corner of the house. I notice it more with the hot water and am considering turning of the hot water preheat as it kicks in pretty regularly.
28 Jul 2003
Dundee
Where's your boiler located?
I can hear it in the bedroom above, even though it's closed off in the utility space off the kitchen. Tbh there's quite a lot of noise around my house anyway so a boiler flashing up isn't going to be an issue
OP
18 Feb 2007
London
Mines silent. But I had the sense to put the boiler in the garage.
Silent because it’s in the garage or is it actually silent when operating, also have you ever checked the efficiency level, mines at 51%, but perhaps that will increase over time, only fitted in April.
Mines in kitchen, the noise is not exactly noisy loud it just seems quite loud compared to some others I have heard.
28 Jul 2003
Dundee
How were you checking the efficiency?
I have put the heating to the eco position and adjusted hot water to 50c as you shouldn't need it hoter than that. Also I think preheating the water is set to off.
9 Apr 2007
Yeah my efficiency shows fairly low like high 40s. Yet I barely use any gas so I just ignore it.
Mines running with Opentherm so runs efficient because of that.
Water is set to 52c.
All boilers are loud to me and not something I want in the house. The dryer and washer are in the garage as well.
OP
18 Feb 2007
London
On the lcd display in menu I have a check boiler efficiency, perhaps yours is slightly different.
Mine shows 51%, I believe higher the more efficient, perhaps it gets better over time. I have my water in the 60s I think which the boiler man set it at. Unfortunately we don’t have a garage or a room suitable other than the kitchen.
thanks for the responses guys
1 Mar 2010
Our Ideal/logic is in a cupboard in kitchen (with open top/bottom - could put insulation on sides?), far less noisy than extractor fan
keep meaning to monitor how much gas this uses .. buying new, would prefer a timer to enable pre-heat in useage hours.
