Man of Honour
- 12 Jul 2005
- Aberlour, NE Scotland
I did say that a i5 wasn't a worthwhile upgrade from your i3. At least the temps are good. Go into the bios and enable MCE (Multi Core Enhancement) which may fix your all core speed to 4.1Ghz instead of just a single core (not sure if this works on locked cpu's but it's worth a try) and then do some gaming and see if you are maxxing the cpu out still.
