Incredible aren't they!
I'm sure the science behind them is total BS but they look really cool and whisky tastes good enough out of them for my pleb palate!
Was literally thinking that and looking at the Auto Glym kit today! Let me know how you get on with it!Will try cleaning my own car for a change!
Not looking forward to mop and bucket in this cold though![]()
Will do. Have also bought a pressure washer which is somewhat excessive since before today I hadn't even cleared the rubbish out of my car![]()
Pro tip, you arent meant to use the pressure washer inside the car
If it a Merc is fine to pressure wash the inside...Pro tip, you arent meant to use the pressure washer inside the car![]()
For Sale: Mercedes CLS 350, clean, low miles.
Being as the weather man has forecast another winter like 1962/3 I thought better get some winter tryes with tread on them -The drive wheel tyres I now have are half worn. Rears have about 6/7mm.
Check your insurer doesn't consider winter tyres as a modification they have to be informed of to not invalidate your insurance (yes, some do).
Should’ve gone with ContiWinterContacts. Everything else is subpar.I think you will find that it doesn't have to be declared anymore - I rang my insurance company 5 yrs ago and they said its not needed. Also read it the other day on a motoring web site.
I read the weather forecast in one of the large comics - Guardian or Sun.
