Can't access OCUK forum (and some others)...
Caporegime
30 Jul 2013
..On my Home PC.
It says: ERR_CONNECTION_TIMED_OUT
Mobile phone on the same network (via WiFi) and same browser (chrome) can access it fine.
I've flushed the DNS via command prompt. What other things could be causing it? Windows 10 firewall is disabled.
See what your proxy settings are set to (Settings->networks and internet->proxy) sometimes 3rd party (malware) software will try and hijack your connection to inject ads, etc.
What ip address and response do you get if you open command prompt and type "ping forums.overclockers.co.uk" ?
I've sorted it.
I'd accidentally plugged the network cable in to Ethernet 2, which on my Aorus X570 Xtreme motherboard is a 'GIGABYTE 10Gbit Network by AQtion AQC107'
For some reason, though the majority of websites worked, this one didn't.
I've plugged it in to Ethernet 1 (Intel(R) I211 Gigabit Network Connection) and it's working fine now.
I wonder if that's also why my PC kept rebooting when I shut it down...will test now.
Edit - Yes, solved that as well. Must have had 'wake on LAN' enabled for Ethernet 2
