MrKnifeys MK2 Escort Project Thread
OP
3 Aug 2008
Nelson, South Wales
Been plugging away at bits slowly. Most of the turbo parts turned up this week. So installed a G19 Manifold and Downpipe, TD04 Turbo and run the feed and return lines to it for the oil and coolant. Bosch 640cc Injectors, which are neatly installed now. Swapped over to the MK2 Cam Cover so I can use the Cam Sensor. Installed my ME221 and then modded the engine loom to the bare essentials. I had it running (I have got a video but cannot upload it), but a fuel leak in the middle of an AN line stopped play! Really annoying as its a manufacturing issue as well! But at least I know my engine harness works, my car harness works and MK1-MK2 engine elec conversion worked as well! :D
Another job ticked off was the propshaft, had a custom shaft done with heavy duty ends all brand new for £185! Bargain
Some pictures as well, I try to get more but not sure anyone wants to see photos of me sat for two hours cutting and taping wiring!
640cc Injector Goodness
G19 Manifold and Downpipe with Cheapo TD04L Turbo
Propshaft
Front pic of car to show engine height
OP
3 Aug 2008
Nelson, South Wales
Nothing really exciting to update you guys with, been adding some more Fuel Line fittings for the bulk head, got the clutch pipe in and bled and pulled it forward under its own steam.
Only cool thing to take a photo of is the Wilwood brakes for the front turned up today. Good news, they look epic. Bad news, they dont fit my wheels!
OP
3 Aug 2008
Nelson, South Wales
Completed the intercooler install and pipework routing. Wasnt a hard task just time consuming. I will eventually change it to as much hard pipe work as I can, once I buy an ally welder and learn how to ally weld! LOL
Also the new wheels turned up, which clear my front calipers (YAY). I went for a much smaller tyre to give me more clearance, also to allow me to drop the car to my desired ride height :)
Deleted member 66701
D
Enters thread, expects to see at least a nicely fettled Pinto in the engine bay, maybe on throttle bodies, sees and abomination of a Mazda engine, leaves thread.
